Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Problem with car audio system
Author Thread: Problem with car audio system
Username: Kbausc
i have a problem with my car sterio the speaker out puts wont work all the wireing is fine and my amp puts sound out fine iv tryed everything i can think of and nothing works i even got a new deck witch is a pioneer deh-2700 my amp is a dual 480 watt powering 2 12" dual subs. the deck is powering 2 dual 6 1/2" and 2 audiobahn 6x9s help me pleas
Username: Joe718
Brooklyn, NY
Post Number: 342
are you sure that when you installed the speaker that the terminals arent touching the body of the car. That will make the radio go into protect. Are you using the factory wires becasue some cars have built in amps, that maybe the reson why your speakers arent getting any sound. If thats the case you will ahve to find the amps main power line and remote line, or just run your own wire to each speaker from the radio
Username: Kbausc
thank you very much one of the terminals was tuching the car body i am in your debt
Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Problem with car audio system [ « Previous ] [ Next » ]
