Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Amp keeps shutting off
Author Thread: Amp keeps shutting off
Username: Dave34
I have a Bazooka Mobile Audio 1500w amp,and a set of Blaupunkt Overdrive ODWA1000,4 ohm,(175+175 rms).My problem is my amp keeps shutting off when i turn it up.I was told to make sure my ground is good,and i'm sure it is.How can i solve this problem??
Username: Vaio
Post Number: 50
check your wires.
Username: Dave34
I dont know too much with hooking up stereos and amps but all i did was pull out one amp and replace it and also replaced subs with same wiring as before,didnt have problem with other system
Username: Kojak28
Augusta, GA
Post Number: 115
How do u have your subs wired?
Username: Truckguy
Mission, Tx
Usa
i had same problem so i changed the fuse from a 25 to a 30 and my problem was solved
Username: Hittmann
Adelaide, South Australia
Australia
Post Number: 12
yeah i suggest to check your fuse also i had this problem and it ended up being that the fuse was dodgy. It didnt look blown but when there was no power i checked with a mulitmeter and there was power to the fuse but not past it.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Amp keeps shutting off [ « Previous ] [ Next » ]
