Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Wiring question
Author Thread: Wiring question
Username: Nickb920
Post Number: 11
When i am connecting the power cable do i need to disconnect anything on the battery(negative terminal) so i get shocked while im unscrewing it? id rather not get electricuted lol
Username: Perrydog
Flint, Michigan
Post Number: 78
all i did was just pull out the fuse under your hood the is in your power cable line, so that no power was runnin thru the wire
WC
Yes you do disconnect the negative terminal first, and connect it last. Make sure you connect your ground wire first on your amp, becuase if you connect the RCA wires first, the amp will think that the RCA wires is the ground and could fry your head unit and maybe your amp.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Wiring question [ « Previous ] [ Next » ]
