Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Connecting 2 amps for 2 subs
Author Thread: Connecting 2 amps for 2 subs
Username: Miso
Slovakia
Post Number: 41
i´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to connect the other one,but it is unable to send unfiltered signal from it,so i´m using Y-splitter to feed both of them and it seems to be fine(is it?).But when i think about it,are these 4volts getting to BOTH amps line-in or are they divided,so i´m getting only 2volts each? Nobody could answer me this question,so i´m asking you guys,thanks.
Username: Miso
Slovakia
Post Number: 42
anyone?
Username: Vaio
Post Number: 51
that right on the 4v but it will work for 2 amp.
i have 3 amps out of a 8v HU. if the amp will not turn on. check your wires.
Username: Miso
Slovakia
Post Number: 43
yes,they are turned on,but my concern is:am i driving them with 4v or 2v each?
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 739
Your h/u is seeing half the impedance, but voltage should remain the same(4v to each). A decent h/u will simply provide twice the current w/o a significant voltage drop.
-Fishy
Username: Miso
Slovakia
Post Number: 44
It´s alpine 9835,so it should be decent enough.But installation guy says itœ providing only 2volts,so he´s wrong,right?
Username: Carguy
Post Number: 2051
Tell him to prove it. In fact ask him to stick 2 pins in the wall outlet and touch them. If he survives that, then politely enquire about which pin gave more shock.
The correct answer should be "equal".
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Connecting 2 amps for 2 subs [ « Previous ] [ Next » ]
