Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Power Surge? Question
Author Thread: Power Surge? Question
Username: Extazy911
I am getting ready to install my system (all but the HU) tomorrow and have one nagging question. My buddy and I have almost the exact same set-up (his is already installed) and when he turns on his HU the amp turns on and the sub makes a loud "thump" from the power surge. Can't that damage the system (amp, speakers, etc)? I am going to be using MUCH larger gauge of wires all around on my set-up, and I am deathly afraid that I am going to have an even larger power surge. Since I will have the interior of my car pretty much scattered to the four winds of my garage (until my HU arrives) what can I do to avoid/prevent this problem, before I put my car back together. I am going to be using an in-line switch on my remote wire (as mentioned in a previous thread). Is there anything I can do to not have this annoying/scary/potentially detrimental sound at startup? Any and all advice will be much appreciated.
"Shoot'em in the face...and walk away laughing" - X
nick_sq
This is a ridiculing problem that just seems to pop up outa nowhere...first off get a ground loop isolator, and if you have more than 1 amp, ground them at dfferent locations. Alot of times the ground wire in the dash is not sufficient, so you should probly make a new ground. I had a kenwood deck that no matter what i did it always thumped when i switched tracks...didnt do it in a buddies car (with subs aswell) but it always did it in mine..drove me mad!
Username: Southernrebel
Monroe, Louisiana
Post Number: 473
yep...those "turn-on pops" drive me crazy too
make sure that everything in you audio system has a good ground...like nick said, try regrounding you HU.
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 724
If nick's referring to an inline(rca) ground loop isolator I wouldn't recommend it. They and LOC's are basically the same beast(matching transformers) and suffer from the same problems: added distortion and reduced frequency response.
Although I never noticed much distortion when utilizing one I did notice significantly reduced low end extension.
I'm really not sure how a ground loop isolator would help your situation anyways. That popping noise is usally eliminated in higher end amps with the use of a turn-on delay. I figured all of today's amps would have that feature by now.
-Fishy
Username: Kojak28
Augusta, GA
Post Number: 117
The fish is right. Power-up delay switch. That will do it. By chance, what amps u guys got hooked up,are gonna hook up?
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Power Surge? Question [ « Previous ] [ Next » ]
