Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Amp problems possibly?
Author Thread: Amp problems possibly?
Garren Keith
I decided to hook up my speakers today after unhooking them quite a while back. I think I might've made a big mistake. I accidentally put the power wire to the ground on the amp and the opposite for ground. I was alarmed when I smelled smoke. I immediately unhooked it. It was only like that for about 10/15 seconds. The amp still comes on but I put my speaker wire from the amp to my speakers correctly, and no sound comes out the speakers. Any suggestions?
Username: Carguy
Post Number: 2030
Unhook the amp from the HU first. Then take one of the rca input cables on the amp and lightly touch it with your thumb. If the amp makes a humming noise, then it's good. If you hear nothing, then try the other channel.
If that's silent too, then most likely your amp is blown. It only takes fraction of a second to blow electronics.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Amp problems possibly? [ « Previous ] [ Next » ]
