Thread: 3 Ohm amps |
Bronze Member Username: Adampit
Post Number: 28 Registered: Dec-04
| Posted on Sunday, March 20, 2005 - 11:35 am: |
I am buying a 12w7 on thursday in a HO box,now i need to buy a 3 ohm amp. When i look for amps if it says for example 1200 watts at 2 ohms and 900 watts at 4 ohms, does it mean that it is around 1050 watts at 3 ohms??? |
Silver Member Username: Addicted2bass
Miami,
FLORIDA
Post Number: 274 Registered: Nov-04
| Posted on Sunday, March 20, 2005 - 11:44 am: |
yeh just aroudn around that amount, but it can differ, because that amp you mentioned above has funny power loads. usually if an amp is 900w rmswatts at 4 ohm its usually at 2 ohms around 1800rms watts. So at 3 ohms theres no way to tell exactly how much power is going to go to the subs but it should be anywhere from 900-1200 rms which is okay for that sub |
Post Number: 30 Registered: Dec-04
| Posted on Sunday, March 20, 2005 - 12:12 pm: |
Opinions on MTX Thunder 1501D amp for the 12w7 750x1 @ 4 ohm 1500x1 @ 2 ohm or would one of the Hifonic amps be better? |
Miami,
FLORIDA
Post Number: 285 Registered: Nov-04
| Posted on Sunday, March 20, 2005 - 12:15 pm: |
no i would recommend mtx over hifonics any day. That amp is a good amp. Have you considered the jl 1000/1 amp |
Post Number: 31 Registered: Dec-04
| Posted on Sunday, March 20, 2005 - 01:06 pm: |
too much $$$$ for the jl otherwise yes i would purchase that one lol |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 540 Registered: Jun-04
| Posted on Sunday, March 20, 2005 - 08:07 pm: |
Since your running the ported box the jl 500/1 would be fine, and a little cheaper than the 1000/1. IMO I wouyld spend the extra cash on the 1000/1 |
Post Number: 32 Registered: Dec-04
| Posted on Sunday, March 20, 2005 - 11:19 pm: |
What is the credability of Viper 1200.1 and Directed Audio amps... ive been told to look at those from a local stereo place that deals them |
Post Number: 33 Registered: Dec-04
| Posted on Tuesday, March 22, 2005 - 10:40 am: |
thoughts on the Viper 1200.1 to a 12w7? |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 320 Registered: Oct-04
| Posted on Tuesday, March 22, 2005 - 01:18 pm: |
#1) I'd save up the money for the JL 1000/1 amp or even a JL 500/1. #2) If you really can't afford getting a quality amp after spending all that money on the box and sub, I'd go with the MTX amp over the Viper amp. |
Post Number: 35 Registered: Dec-04
| Posted on Tuesday, March 22, 2005 - 01:52 pm: |
Well i am getting the sub in the box from a friend for a very low price, The JL amp is what, 700 bucks, thats alot of money for a amp. Out of my price range. I have to find an amp for around 300-400 bucks. And i went to a MTX dealer and they said that the mtx amp is too powerful for a w7. Any suggestions please on other amps in that price range that would work well please tell me. thanks |
