Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > How to .....2nd remote wire
Author Thread: How to .....2nd remote wire
Username: Metalgearsolid
NJ
Post Number: 20
i want to install 2 amp in my car . so, i was wondering, how can i split the remote wire? i can use distribution block for 2 Positive + wires and negetive wires are not a problem. But how can one remote wire could be splited so that both amp gets it in the remote wire terminal? thanks.
Username: Tragedy
San Jose, CA
Post Number: 79
Just splice into your current remote wire going to the one amp and run a lead to the other. You will have no problems with that.
A.C.
Ya do what tra gedy said, i have four amps current runnning off one rem wire and i have no problem with it.
Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > How to .....2nd remote wire [ « Previous ] [ Next » ]
