Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > BEST AMP 600W RMS @ EITHER 1 OR 4 OHM
Author Thread: BEST AMP 600W RMS @ EITHER 1 OR 4 OHM
RAY B210
YEA...WHATS THE BEST AMP THAT WILL GIVE ME THIS AMOUNT OF POWER AT EITHER A 1 OR 4 OHM LOAD??? QUALITY AND POWER IS MORE IMPORTANT TO ME THAN MONEY....BUT I MEAN, IM NOT LOOKIN TO SPEND TOO MUCH EITHER...I JUST NEED TO KNOW WHAT AMPS ARE THE BEST, I CAN SURF THE NET TO FIND A GOOD PRICE.
Username: Carguy
Post Number: 2013
Try Zapco, Arc Audio, US Amps, PPI PC/PCX series and Art series, Orion HCCA, JL, Xtant.
RAY B210
SWEET...any specific models?? i was shoppin at a few local dealers....and wut sounds good so far is either MTX THUNDER502, KICKER 450.2, the JL500/1 (seems to be more expensive tho), and ALPHASONIK PMA2150A
Username: Adampit
Post Number: 27
PPI PCX-2125 is 500x1 @ 4 ohm
i think i've heard its under rated
JL 601.1
i mean jbl
RAY B210
what about the mtx or the kicker that i was SOOOO close to buying??? any good? cuz i can get them for 200 shipped on ebay :-)
Username: Carguy
Post Number: 2046
What were those models on eBay? Some of them are okay, while others are suspect.
The problem with buying cheap amp is, sooner or later you'll want better sound quality.
Username: James1115
Wilton, Ct
Post Number: 1989
if you want 600 watts at 4ohms make no mistakes and get the PPI A600.2 hands down! done deal!
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > BEST AMP 600W RMS @ EITHER 1 OR 4 OHM [ « Previous ] [ Next » ]
