Thread: Zapco C2K 2.0!! |
Silver Member Username: Joebruce
KY
U.S.A.
Post Number: 167 Registered: May-04
| Posted on Friday, March 18, 2005 - 12:51 pm: |
Hey I just won an action for a zapco c2k 2.0,I got it for $247.50 shipped!! You think I got a good deal,I mean they retail for $600. Ill be using it for my sub right now but somewhere down the road i might use it for some mids/highs.Im just bored so i figured il let you all know. |
Gold Member Username: Carguy
Post Number: 2004 Registered: Nov-04
| Posted on Friday, March 18, 2005 - 01:23 pm: |
Congradulations. C2K are great series amp. I have my eyes on C2K 6 model. |
KY
U.S.A.
Post Number: 170 Registered: May-04
| Posted on Friday, March 18, 2005 - 01:29 pm: |
Isaac you need another amp like you need a hole in your head!! But good luck man!! |
Post Number: 2006 Registered: Nov-04
| Posted on Friday, March 18, 2005 - 01:39 pm: |
Those holes can come in handy during hot humid summer! Check out the spec on C2K 6 amp. One of the best. It can also be modified to put out more power without affecting performance. |
KY
U.S.A.
Post Number: 171 Registered: May-04
| Posted on Friday, March 18, 2005 - 01:55 pm: |
Can th 2.0 be modified? And how would you do that? |
Post Number: 2007 Registered: Nov-04
| Posted on Friday, March 18, 2005 - 03:39 pm: |
According to Zapco, they'd gladly modify it for a small fee. On C2K 6, it would be worth it. Instead of getting somewhere around 800w, you can get as much as 1200w rms.
