Thread: Amplifier wiring |
Bronze Member Username: Jeze
Post Number: 24 Registered: Jan-05
| Posted on Thursday, March 17, 2005 - 06:18 pm: |
I wired by dual coil subwoofers the other week successsfully but I may have made an error in the wiring. I wired them at two ohm in series so they should look like the first below.
The problem is that I may have accidentally wired them like the picture below. What Ohm is this and if its something made up, what can this damage? The subs sound is fine but I think the volume should be louder. The only difference is that the + (red) to - (black) wire is on one side opposed to going to the other side of the woofer.
Silver Member Username: Fishy
TamaracFt.Laud,
FL
Post Number: 681 Registered: Sep-04
| Posted on Thursday, March 17, 2005 - 07:49 pm: |
Ummmmmm.... from what I can see, unless you've shorted a voice coil, those are equivalent circuits, i.e. they're both the same.
If you would mark which leads correspond to which voice coil it'd be easier to tell for sure. -Fishy |
Silver Member Username: Byrumjr
Post Number: 123 Registered: Jan-05
| Posted on Thursday, March 17, 2005 - 08:43 pm: |
What are your subs dvc or svc and what ohms? What ohms are you trying to wire them at. |
