Thread: 2 amp install? |
Bronze Member Username: Jlprix91
West,
Michigan
Usa
Post Number: 66 Registered: Oct-04
| Posted on Thursday, March 17, 2005 - 02:17 pm: |
I know i need a two amp kit and all that but some dont have 2 rca's I need some recommendations? cheap ways if possible i dont want to spend $150 dollars on a multi-amp wiring kit |
Bronze Member Username: Tragedy
San Jose,
CA
Post Number: 78 Registered: Feb-05
| Posted on Thursday, March 17, 2005 - 03:49 pm: |
well if you find everything you need in a single multiple amp kit, but are just missing the extra rca cable, then just buy rca in addition or build you own kit either way you should be under $150 |
Silver Member Username: Byrumjr
Post Number: 124 Registered: Jan-05
| Posted on Thursday, March 17, 2005 - 08:48 pm: |
Wall mart has a dual wiring kit for $25 or $ 35 I can’t remember. It have everything you need for two amps and it’s 4 gauge wire. |
Silver Member Username: Jwbulger79
Florida
Post Number: 268 Registered: Nov-04
| Posted on Thursday, March 17, 2005 - 08:55 pm: |
www.knukonceptz.com great stuff. |
New member Username: Balls573
Winona,
Missouri
U.S
Post Number: 10 Registered: Mar-05
| Posted on Wednesday, March 23, 2005 - 11:34 pm: |
Buy the knukonceptz wire. I had the walmart stuff and switched to the knukonceptz wire. If you look at how much wire is in the knukonceptz wire compared to the scosche it looks twice as big almost. |
