Thread: Amp Question for new setup |
New member Username: Tjwash
Myrtle Beach,
SC
US
Post Number: 1 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 12:12 pm: |
I recently purchased the below items for my 64 Chevy Impala and what like to get input on amp ideas. I would like to keep a more stock appearance so I was thinking of the Audiobahn A5100T to use with new items. Would it be better to just buy a JL Audio 1000/1 for my sub, and additional multi channel amp, or will the Audiobahn handle everything I have? 1-JL Audio 10W7 JL Audio XR525-CSI 5 1/4 Comp System JL Audio TR690-TXI 3way 6x9 Speakers Nakamichi CD400 Head Unit |
Gold Member Username: Carguy
Post Number: 1999 Registered: Nov-04
| Posted on Thursday, March 17, 2005 - 02:02 pm: |
Hey Tal, unless you're into surround sound system, that amp isn't practical. You'll be better off with 1 JL 1000/1 amp for the sub, and 4 channel amp for front and rear. If you don't need that much power, JL 500/1 should be fine. Since most of your parts are JL, you might as well go with JL 300/4 amp. |
