Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > Setting up for highs amd mids
Author Thread: Setting up for highs amd mids
Username: Chevelle
Lancaster, Pa
Usa
Post Number: 18
Question when setting up for highs and mids is it best to bridge the 6 1/2 or run them stereo and when setting the amp for hpf's whats the best setting for it around 80hz or 100hz
Username: Carguy
Post Number: 1997
When you say bridge, do you mean left and right channels? You always want stereo for components.
For midbass, set it around 100hz if you get too much cone movement, if not, then 80hz. It all depends no the type of music you listen to.
Username: Chevelle
Lancaster, Pa
Usa
Post Number: 19
ok the reason i ask is i got my subs wired 2ohm and run them stereo i wasn't sure if i should rewire them to make one 4ohm lead to amp and do the same with the 6 1/2's or just leave it the way it is and bridge the 6 1/2 but now i know stereo for mids and highs.So i know now 100hz and if to much cone movement 80hz.The music is mostley bass music i have my subs set at 100hz on lpf does that sound about right for lpf
Username: Carguy
Post Number: 1998
Your setting for LPF is fine. Most people have it around 80Hz - 100Hz.
Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > Setting up for highs amd mids [ « Previous ] [ Next » ]
