Thread: Which amp to push my sub? |
New member Username: Quiksilverx181
Post Number: 5 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 01:05 am: |
Debating between MTX MXA4002, MTX 342 and Audiobahn A4002T... They are all between 300-400 RMS @ 4ohm i believe. My sub is a 12" Infinity Reference sub 300wRMS @ 4ohm. Which one would you recommend for cooling, performnace, and power? |
New member Username: Wcc
Los, angeles,
California
Post Number: 1 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 03:03 am: |
Out of those 3 I will go with the Mtx 342 that will be a good combo. |
Post Number: 6 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 03:25 am: |
Thanks, thats now 3 votes from 3 sources for the MTX 342, thats what i will go with. Thanks |
