Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > Glass.... Amp Choices For Brahma 15"....
Author Thread: Glass.... Amp Choices For Brahma 15".
Username: Swantlaphoenix
Tucson, AZ
Post Number: 43
Im not sure what kind of options I have for amps. The 15" is going to be in a 2.25 sealed box so I'm guessing I'm going to need around 1000 watts. I thought about getting the JL 1000/1 buts its sooo expensive. Any other options under $500 that wouldnt be much different from the 1000/1? Should I really save up for the 1000/1. I know I can get it for like $730.
Username: Southernrebel
Monroe, Louisiana
Post Number: 461
you may wanna look at a kicker kx1200.1
it is a nice amp.
Tucson, AZ
Post Number: 44
Anyone like or have experience with alpine Amps? I thought the "Alpine MRD-M1005" looked good.
Tucson, AZ
Post Number: 45
That kicker will only produce enough if I run it @ 1 ohm. If I run it @ 1 ohm it will really affect the damping factor if I read that correctly somewhere.
Monroe, Louisiana
Post Number: 462
the kicker will work just fine.
the dampening factor will drop at 1ohm, but the kx1200.1 will still be a good amp.
Username: Rob315
Cuse, NY
U.S.
Post Number: 321
if your interested in alpine amps i have 2 new mrd m501 for sale id sell them to you for $450. cheaper than the mrd 1005 and they look better.
Tucson, AZ
Post Number: 46
Well I dunno. Im wondering if the Alpines Are Any good?
Username: Nveselinovic16v
Post Number: 14
is that brahma 2x2ohm?
Tucson, AZ
Post Number: 48
Yea... Well I think. It says 1/2/4 ohm. I know its DVC though
Home > Message Board > Car Audio > Amplifiers > Archive through March 20, 2005 > Glass.... Amp Choices For Brahma 15".... [ « Previous ] [ Next » ]
