Thread: Oscilloscopes??? glass, isaac, anyone? |
Silver Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 458 Registered: Mar-04
| Posted on Wednesday, March 16, 2005 - 11:34 pm: |
i have a DMM and an amp-clamp(the amp-clamp doesnt work anymore though, i think), but i have been thinking about getting an oscilloscope. you know...just for sh!ts and giggles. anyways, i went on ebay a minute ago and found oscilloscopes really cheap. (i was figuring that most of them are prolly crap) http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D7500885752&ssPageName= STRK:MEWA:IT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D7500917001&ssPageName= STRK:MEWA:IT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D7501305988&ssPageName= STRK:MEWA:IT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D3880678062&ssPageName= STRK:MEWA:IT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D5565670936&ssPageName= STRK:MEWA:IT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D7501114668&ssPageName= STRK:MEWA:IT i was mainly looking at the last one (hewlett packard) or the B&K scope...but i dont know much about oscilloscopes. i just wanna get one to mess around with. which of those scopes would yall get if you were getting one??? |
Gold Member Username: Jonathan_f
GA
Post Number: 3496 Registered: May-04
| Posted on Wednesday, March 16, 2005 - 11:47 pm: |
Didn't see any of the links working. Anyway, either of those will work (HP or B&K), but IMO Tektronix makes the best scope if you can find one for a reasonable price. |
Gold Member Username: Carguy
Post Number: 1990 Registered: Nov-04
| Posted on Wednesday, March 16, 2005 - 11:51 pm: |
Same here, none of the links worked. For Oscilloscope, look for Dual trace, 20MHz - 100MHz. |
Monroe,
Louisiana
Post Number: 459 Registered: Mar-04
| Posted on Thursday, March 17, 2005 - 12:18 am: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=45005%26item%3D7500190609 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=45005%26item%3D7500885752 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=45005%26item%3D7500401071 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=97193%26item%3D7501114668 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=58280%26item%3D3880876730 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=58282%26item%3D7500617307 %26 what about one of those? they are just a few random ones that i found...all i want is a simple lil scope. some of the ones i saw on ebay are going for really low prices. |
Post Number: 1991 Registered: Nov-04
| Posted on Thursday, March 17, 2005 - 12:25 am: |
It still doesn't work for me. If you want something to play with, get the 20MHz dual trace model. I saw one for $40. That's the price of a normal DMM!
Monroe,
Louisiana
Post Number: 460 Registered: Mar-04
| Posted on Thursday, March 17, 2005 - 12:38 am: |
Tektronix R561B TEK 7623A HEWLETT PACKARD 54501A 100Mhz TEKTRONIX AN/USM-425 (V)1 Hewlett Packard 1740A 100MHz those are ths scopes i am looking at. as of rite now i am the high bidder on the TEK 7623A at a wopping $11.50. yall know anything about those models? or could you suggest a model or where to get one? |
Monroe,
Louisiana
Post Number: 464 Registered: Mar-04
| Posted on Thursday, March 17, 2005 - 05:41 pm: |
^^^do yall know anything about those models???
Post Number: 2002 Registered: Nov-04
| Posted on Thursday, March 17, 2005 - 07:21 pm: |
Marshall you should've posted the Item number from eBay. Much easier to search. The HP 54501A isn't bad at all for $1. It comes with everything you need to experiment. You won't need anything greater than 100Mhz for working with audio equipments. In fact lot of the old shops still use 20Mhz. Stay away from auctions that do not include probes and accessories. They will cost you almost as much as the unit itself.
