Thread: Wiring to get 2 Ohms |
Ben Koehler Unregistered guest |
| Posted on Wednesday, March 16, 2005 - 07:03 pm: |
I just bought an audiobahn 8000T and it says to get 800w wire it at 2 Ohms. How do i wire 2 4 ohm dual voicecoil subs together to reach 2 ohms? |
| Posted on Wednesday, March 16, 2005 - 07:19 pm: |
Anyone know? |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 102 Registered: Feb-05
| Posted on Wednesday, March 16, 2005 - 07:29 pm: |
either wire the VC's of each sub in series, then the subs in parallel or wire the VC's of each sub in parallel, then the subs in series. i think the first set up is reccomended though |
Nick_sq Unregistered guest |
| Posted on Wednesday, March 16, 2005 - 08:26 pm: |
hmm, lets see here. If you series the voice coils each sub would be 8 ohms, combne those subs in parallel and your back to 4 ohms. If you parallel the voice coils to 2 ohms each sub, then series the subs together, you get 4 ohms again. So, you are royally SOL! 2 ohms cant happen. You could however, get a 1 ohm load, but i would have serious doubts in my mind that an audiobahn could drive a 1 ohm load without turning into liquid chrome. Get a better amp. |
Stockbridge,
GA
Post Number: 103 Registered: Feb-05
| Posted on Wednesday, March 16, 2005 - 08:34 pm: |
haha, sorry, thought you were trying to get them to 4 ohms, misread your question. get 2 more subs, then you can get it, lol |
| Posted on Wednesday, March 16, 2005 - 09:40 pm: |
So there is no possible way to get them to 2 ohms? |
Stockbridge,
GA
Post Number: 104 Registered: Feb-05
| Posted on Wednesday, March 16, 2005 - 09:54 pm: |
nope, but i'm sure you could like wire up resistors from radio shack or something, but you'd prob just end up screwing some stuff up, lol |
| Posted on Wednesday, March 16, 2005 - 10:01 pm: |
I guess i'll have to settle with 400 watts instead of 800 watts. (tear)
| Posted on Thursday, March 17, 2005 - 12:58 am: |
well, + in the audiobahn factor and you get about 200 watts, with about 90% distortion lol. |
Bronze Member Username: Krijgy
Smithfield,
Virginia
United states
Post Number: 77 Registered: Jan-05
| Posted on Thursday, March 17, 2005 - 09:45 am: |
just as brandon said wire up some resistors, but i think you would be better off using inductors instead of resistors. |
| Posted on Friday, March 18, 2005 - 03:49 pm: |
how do u wire 2 subs to get a 1 ohm load? any sub...any amp |
