Thread: Ne one have suggestions to what Amp i should get??<< |
New member Username: Kaine1021
Post Number: 7 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 06:36 pm: |
I dont know much of anything when it comes to amps so if ne one has ne thing to add when picking an amp or anything about an amp i need to know tell me. By the way i have Rockford Fosgate 2 12's w/400 watt RMS and 4 Ohm impendence and 1 15 w/500 watt RMS and 4 Ohm impendence. or email me atskyline_ryder10@hotmail.com |
Gold Member Username: Invain
Michigan
United States
Post Number: 1726 Registered: Aug-04
| Posted on Wednesday, March 16, 2005 - 06:52 pm: |
Well, if you really wanna run 1 15 and 2 12's then I'd get one amp to run the 15 and one amp to run the 12's. |
Silver Member Username: Joebruce
KY
U.S.A.
Post Number: 159 Registered: May-04
| Posted on Wednesday, March 16, 2005 - 07:36 pm: |
Thats not really a good idea running 2 12" and 1 15" it would sound kinda weird i would think. i would just go with the 2 12"s look at jl,mtx for an amp. |
Post Number: 8 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 07:49 pm: |
why would ti make it wierd. The 2 12s would ahve more bass over the 15 or sumtin? |
Post Number: 9 Registered: Mar-05
Michigan
United States
Post Number: 1729 Registered: Aug-04
| Posted on Wednesday, March 16, 2005 - 08:03 pm: |
It's always a good idea to run all the same sized drivers. The different sizes can make the bass sound different and will have slightly different frequency response. It just doesn't sound any better than having all the same size. |
KY
U.S.A.
Post Number: 162 Registered: May-04
| Posted on Wednesday, March 16, 2005 - 08:10 pm: |
"It's always a good idea to run all the same sized drivers. The different sizes can make the bass sound different and will have slightly different frequency response. It just doesn't sound any better than having all the same size." Thanks now i dont have to do all that typing! |
Bronze Member Username: Kaine1021
Post Number: 11 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 09:21 pm: |
Alright thanx for the help but now i need to know what amp i should get for them I might get 4 12's then. I jsut dont know how to tell what amp to get by looking at the RMS and the Ohms. |
