Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Should i get crossovers or what shoul...
Author Thread: Should i get crossovers or what should i do???
Username: J_2_tha_c
Sydney, Nsw
Aussssstralia
i am hooking up two audiobahn subs with 600 watts each goin into them and then i just have normal kenwood 4 inch speakers running at the 52 watt ouput of the head unit what should i do to get the best quality sound, good for all types of music from punk to dance etc. p.s my amp doesnt have a crossvoer it has little dials for treble, bass and gain so im not sure if i use them or not???
thankss heaps
Username: Subfanatic
Walton, Ky
Post Number: 1123
whats a crossover
Username: Jwbulger79
Florida
Post Number: 290
get some bassblockers for your 4" speakers.
http://www.crutchfield.com/cgi-bin/ISEO-rgbtcspd/ProdView.asp?i=127BB600a2
Florida
Post Number: 291
they are essentially capacitors, or simple passive crossovers.
http://www.the12volt.com/caraudio/cross.asp
http://www.bcae1.com/xoorder.htm
Florida
Post Number: 292
if you want to save a couple bucks, you can get two of these:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=027-356
hook them up to the positive side of your speaker wire. they are the same thing as the 600 Hz Bassblockers.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Should i get crossovers or what shoul... [ « Previous ] [ Next » ]
