Thread: Hello, new to forum, got few questions |
New member Username: Quiksilverx181
Post Number: 1 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 03:11 am: |
Hello, I just bought an Infinity 12" Subwoofer, 300rms @ 4ohm. I hooked it up to an Infinity 7520a 2 channel amp, which is rated for 283w RMS @ 4ohm. I ran my new sub/amp combo for 1 hour, and then my sub started cutting out. I go to my amp, and its SCORCHING hot. I went back to the professionals who installed it for me, and they tested the grounding, impedance, and everything. All was fine. We are guessing its the amp. Now I talked to cardomain and I am returning it tomorrow. Which amp should I get now? Should i buy an amp with more than 300w RMS @ 4ohm so my sub could get a bit more juice? I have a $150 limit, but if you have to, as high as $199. I was looking at a MTX 342, which is 340w RMS @ 4ohm, is MTX good? Also, I am hearing about "fake" wattage, and that you have to calculate the real values of equipment. How do i do this, and how can i tell if something is fake? Thanks |
Gold Member Username: Taylor17
Kopperl,
Texas
Post Number: 1032 Registered: Jan-05
| Posted on Wednesday, March 16, 2005 - 10:04 am: |
As long as you stay away from Legacy, Sony... thing's that look to good to be true, you will get real watt's. MTX is a great brand. They make nice stuff, with out the really high price! |
Post Number: 2 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 12:36 pm: |
I Hear of overheating problems on MTX's, they wont die on me will they? |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 308 Registered: Oct-04
| Posted on Wednesday, March 16, 2005 - 03:38 pm: |
Were you running your setup at like full power? Also, was the sub DVC or SVC? Make sure you wired everything correctly? Otherwise it sounds like your amp could be dead. MTX sells pretty good quality stuff. They won't die on you. |
Post Number: 3 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 09:03 pm: |
I was close to full power. Will that do it? Will getting a more powerful amp fix that problem? |
Post Number: 4 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 09:16 pm: |
How are Power Acoustik TS620-2's? Its rated for 360w RMS @ 4ohm... http://www.crutchfield.com/S-I8DRqt...110&I=026TS6202 How would that amp do with powering my sub? Will it do well? Is that power rating real or fake?
