Thread: Altanator? help &few other question |
| Posted on Tuesday, March 15, 2005 - 06:51 pm: |
Alright i have two kicker l7 12's and am planning to get two boss riot 1500d's.. how is this amp? also my friend told me that i might need an altanator because ill be pusing 1500watts rms. how many dbs is that? if i do get an altanator now many amps should i gett? thanks a lot KAM |
Silver Member Username: Ctx
Post Number: 109 Registered: Jun-04
| Posted on Tuesday, March 15, 2005 - 08:59 pm: |
you could do better as far as amps go, it depends on what kind of car you have for the alternator question |
| Posted on Wednesday, March 16, 2005 - 02:53 pm: |
yea but wouldint i get the same strenght in bass using ne other amp that cost more? i have a 1995 bmw 325is i mean 200 bux for an amp that gives 800rms still gotta sound as good as a 400 dollar name brand amp |
New member Username: Nitescort
Post Number: 10 Registered: Mar-05
| Posted on Wednesday, March 16, 2005 - 03:50 pm: |
no it doesnt
Silver Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 450 Registered: Mar-04
| Posted on Wednesday, March 16, 2005 - 04:21 pm: |
kam, i have messed w/ that boss amp before. it doesnt put out anywhere near 1500wrms. prolly more like 600-700w at 1ohm. all "watts" are not created equal. that boss amp will put out a dirty signal, and it would not sound as good as other amps. i put that same amp on my old L5 12" just to hear it...then i put a jbl bp600.1 on the same sub in the same box. you could hear the difference, it was like night and day. (and the bp600.1 is only a mid-level or maybe a little better than mid-level amp) for $200 you could do better than that boss r1500d. jbl bp1200.1's go for ~$225 on ebay all the time and they will really give you 1200wrms+. and you could get a kicker kx1200.1 on ebay for about $400. you really cant tell how loud a car is with out getting it metered.
