Thread: Some type of input?? |
| Posted on Tuesday, March 15, 2005 - 08:31 am: |
What do you guys think about Rockford amps, especially the power series which is whatim running. And they come out with a new amp this year the t3002 or sumthin, and i have it in my car runnin to my doors, do you think they are good quality amps??? |
Gold Member Username: Carguy
Post Number: 1930 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 10:17 am: |
They're good amps. You should be satisfied with them. I would've bought Orion HCCA or PPI's art series/PC/PCX. |
| Posted on Tuesday, March 15, 2005 - 10:21 am: |
are they expensive???? |
Post Number: 1934 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 11:15 am: |
No they're in the same price range as RF, if not cheaper. Take a look at PPI's 600.2 or 300.2 amps on eBay. PPI PC2300.2 is also a great amp. |
| Posted on Tuesday, March 15, 2005 - 11:32 am: |
what are some of the better things about PPI than RF??? |
Post Number: 1937 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 12:27 pm: |
Well for starters, it's designed with quality in mind. Better SQ, SN Ratio, Slew Rate, Channel Separation, Damping Factor, Bandwidth, and best of all, it gives you clean useable power. Try 600.2 amp out for yourself and you'll know why it was one of the best amps made. |
