Thread: Sound difference between 1ohm, 2ohm, 4ohm etc... |
Bronze Member Username: Invictuz
Seattle,
Wa
Usa
Post Number: 30 Registered: Jan-05
| Posted on Tuesday, March 15, 2005 - 07:21 am: |
Assuming deck/power/cabling is the same is there a difference in sound at 1ohm, 2ohm, 4ohm etc...? Does 500watt at 1ohm sound any different than 500watt at 4ohm?
Gold Member Username: Invain
Michigan
United States
Post Number: 1690 Registered: Aug-04
| Posted on Tuesday, March 15, 2005 - 08:43 am: |
Nope. |
Gold Member Username: Carguy
Post Number: 1929 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 10:14 am: |
In theory, you will get better sound quality at 4ohms, but in reality, not sure if your ears are that sensitive. Amps designed for 4ohms, running @ 1ohm will burn more power vs amps running at 4ohms. Mainly due to heat and inefficiency.
| Posted on Tuesday, March 15, 2005 - 12:21 pm: |
1 ohm hit harder but dont sound that good |
