Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Will they fit
Author Thread: Will they fit
Username: Amoore24
Marshalltown, Iowa
United states
I have a 1997 saturn sc 2 door coup. The stock speakers are blown to crap. They are 5 1/5 inches. I wanna put some bigger more durable speakers in there place, like some 6 by 9's but i was wondering if the 6 by 9's would fit in the same place as the smaller stock speakers. Thanks for any replies
Username: Nnnnick_b
Nc
Usa
Post Number: 208
no, not unless u did some crazy custom work. get a decent component set from alpine or infinities lower lines, or give us a budget and we can give u some more options.
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Will they fit [ « Previous ] [ Next » ]
