Thread: Speaker question |
| Posted on Monday, March 14, 2005 - 08:57 pm: |
since the other forums are down, i'll ask this here. Can i hook up speakers around 200 watt rms to my deck without using an amp? |
| Posted on Monday, March 14, 2005 - 09:20 pm: |
yes.. but they wont sonud as loud if hooked up to a amp |
| Posted on Monday, March 14, 2005 - 09:23 pm: |
you would be interested in a Pyramid 1600watt 4ch amp? email: babygreeneyes805@hotmail.com |
Silver Member Username: Byrumjr
Post Number: 116 Registered: Jan-05
| Posted on Monday, March 14, 2005 - 09:29 pm: |
If you are talking about speakers then yes. But Subs need more watts than a head unit can put out. It would work but they will not sound good also in order to hear them you will need to turn the head unit up so high it will send a clipped signal to the subs and mess them up. |
| Posted on Monday, March 14, 2005 - 09:30 pm: |
i hear pyramid is no good tho what specs would i look for in an amp to power 200 watt rms speakers |
| Posted on Monday, March 14, 2005 - 11:43 pm: |
what amp should i use on speakers about 200 w rms? I'll need amps for my speakers and subs so do they have to be the same or have similar specs? can i bridge speakers? any help is great.
