Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Can I hook up 2amps to 2 12cvr
Author Thread: Can I hook up 2amps to 2 12cvr
Username: Jaedpi
I have 2 12cvr and a kx450.2 amp w/ 1 12 per channel. I am wanting to buy a kx250.2 is it possible to install both amps to the same subs or do I need to buy one big amp. And if it is possible to use both amps how should I connect them to the 12. I will Appreciate any help i can get.
nope, you cant hook a 450.2 and a 250.2 together at the same time. it just doesnt work that way.
if you want more power, you will have do buy a bigger amp.
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Can I hook up 2amps to 2 12cvr [ « Previous ] [ Next » ]
