Thread: Amp help please<<<<< |
Bronze Member Username: Volsrule2069
Post Number: 20 Registered: Feb-05
| Posted on Monday, March 14, 2005 - 11:59 am: |
alright on the side of my amp i have 2 nobs taht say HPF and LPF and i can adjusst them by turning the nobs, there is also a switch, you can have the switch pointing to one of 3 things: HPF LPF or FULL, i keep it on full bc thats what it was one hwen i got it, but i found that when it is on HPF it is a lot louder and deeper, what does HPF and LPF mean? and would it be bad to keep it on HPF? would taht mess anything up? |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 978 Registered: Jan-05
| Posted on Monday, March 14, 2005 - 12:46 pm: |
It just has to do with the frequencies you're sub's play. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 302 Registered: Oct-04
| Posted on Monday, March 14, 2005 - 01:18 pm: |
Set your LPF to 80hz, your HPF to 20hz, and the switch should probably go on HPF. LPF = Low Pass Filter HPF = High Pass Filter |
New member Username: Coronababe
Post Number: 1 Registered: Mar-05
| Posted on Monday, March 14, 2005 - 11:15 pm: |
I am planning on buying a full system for my jeep wrangler I am going to buy 6x9 pioneer speakers for the front(240 watts),6-1/4 pioneer speakers for the back (130 watts),I am also getting a pioneer receiver(DEH-P4700MP)50x4 and I was wondering to get the best sound&bass out of these speakers what should I do? should I add an amp,and if so what kind? if not than what do you prefer that I do? and is my overall speakers and receiver pretty good picks? |
