Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Amp for 2 JLW6v2 10s
Author Thread: Amp for 2 JLW6v2 10s
Username: Lakerlax
Hey im new here looking for some advice-
I have 2 JLW6v2s in the JL sealed box, I am currently running a 1000w kenwood s*** amp with them and i feel they are underpowered. they are in a 330xi. I was wondering what amp would give them ample power without too much cost. Thanks
Username: Lakerlax
Sorry the subs are 10"
Username: Taylor17
Kopperl, Texas
Post Number: 976
How much money are we exactly talking about? What is the rms on the 10's?
Username: Joe_c
Oakwood, Ga
Post Number: 64
I HAVE 500/1 ON MY ONE 10 AND IT JAMS SO GO WITH 1000RMS NOT KENWOOD 1000W
abraham
go wit a bazooka amp.. like 800watts or less.. wire the subs in parallel and get thick azz wire and a short ground but thick wire.. this should push your jl subs good..
Username: Subfanatic
Walton, Ky
Post Number: 985
dont get a bazooka amp, what kind of money are you looking to spend
abe
bazooka amps are good amps.. the older ones.. you can get a good 700watt mono bazooka amp off ebay for 50-60 bucks.. good power.. cheap price..
Username: Joe_c
Oakwood, Ga
Post Number: 65
bazooka is crapooka, get somethin w/ some clout
huff
joseph does the jl hit hard does it shake the car i was thinkn of getting two tensw6 but iwant to know if they sound like if it was 12" speakers. thanks
Username: Mrsoundquality
Long beach, California
California
Post Number: 13
we all know that jl is the best out there but guys dont forget theres gotta be some other better one like the all new mb quart
Username: Joe_c
Oakwood, Ga
Post Number: 73
mb subs dont even compare , and yes the one 10 hits harder than my buddys TWO 12's . the hype is real
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Amp for 2 JLW6v2 10s [ « Previous ] [ Next » ]
