Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Looking for 2-channel 50W RMS amp for...
Author Thread: Looking for 2-channel 50W RMS amp for components
Username: Minime80
Post Number: 84
What do you guys suggest (50Wx2 RMS @ 4 ohms per channel).
Username: Minime80
Post Number: 85
I can get a PPI PCX-250 for $80. How's that? (I know Isaac will like this one)
Username: Carguy
Post Number: 1877
Nick if you could get that amp for $80, go for it. PPI's PC and PCX series are great amp. They are priced below MTX and probably in the same range as Pyramid. However, it's night and day in quality comparision.
If you want one of the best sounding amp, look at PPI 2300.2 amp. I have that one. I don't think you'll ever upgrade in the future if you purchase that model. It's 75w rms x 2 @4ohms, and 150w x 2 @2ohms. The damping factor is >500, and slew rate is >50V!
Username: Minime80
Post Number: 86
Hey, do you know the damping factor and slew rate of the PCX-250? I can't seem to find it.
Username: Carguy
Post Number: 1879
If you can't find one for PCX-250, then look for the PCX series amp. They are almost all identical in spec wise.
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Looking for 2-channel 50W RMS amp for... [ « Previous ] [ Next » ]
