Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Alpine CDA-9827 mp3 limit??
Author Thread: Alpine CDA-9827 mp3 limit??
Username: Jwbulger79
Florida
Post Number: 208
i burned a couple cds of mp3s to play in my alpine; put like 105 files on one, 103 on the other. however, the alpine only reads 52 files on each disc. is that the max # of files it will read? if i create subfolders will it allow more?
thanks. the manual doesnt say much. i'm gonna burn another disk with subfolders, but i just wanted to see if anyone had any experience with this.
Username: Kklagge
Post Number: 102
You should be able to read something like 256 files per folder
Florida
Post Number: 216
ok, i burned another disc yesterday, and this time i created subfolders by artist and now it reads all of the files.
burnt
Hey J.W. check the manual and make sure u burn the files according to the recommended "burn method".
If I remember correctly, there's track-at-once and disc-at-once. It says it wont support one of those methods. I cant recall which one. Heh.
Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Alpine CDA-9827 mp3 limit?? [ « Previous ] [ Next » ]
