Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Need help please
Author Thread: Need help please
slm
I'd like to get some speakers. I have money to spend on a deck, subs and amp. I'll have about $100 cdn for speakers. I want 6x9's in the back and I'll have to hack up the front of my car for front speakers. What are some good brands and can you recommend any good speakers for $100 cdn.
I can save up a little more if $100 isn't enough.
Any help is great
slm
I know i dont need rear speakers but i want some 6x9's.
Username: Tips
Post Number: 96
for 100 dollars? if you're looking for 2 pairs of speakers for 100 dolars you wont much good quality stuff. im in the same sitution as you kinda. i went looking for speakers for 100 dollars, and im gonna end up spending around 170. i kno infinity is a really good brand, but even their reference series might be a bit too much if you dont wanna spend over 100. you could try pioneer. im not too sure tho.
Username: Rds11
Louisville, Kentucky
Post Number: 118
you get good speakers if you know where to look.
Infinity, Alpine, MB Quart, Polk, JBL.
Those are some brands that make pretty good stuff. Here are some sites where they sell them pretty cheap.
cbrstereo.com (good site) sonicelectronix.com etronics.com woofersetc.com
Username: Rds11
Post Number: 120
you will need some more money and it will be the bottom line stuff tho
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Need help please [ « Previous ] [ Next » ]
