Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > What exactly does the low boost setti...
Author Thread: What exactly does the low boost setting do a freq setting do?
I have a 2channel not bridgeable hooked up to two 12's I dont think the amp is putting out to its full potential does it have something to do with the low boost setting or the frequency filter setting ?
Username: Joe718
Brooklyn, NY
Post Number: 330
usually they give you a 12db boost at the crossover point that you select, but tthat feature often makes the music sound muzzled and distorted.
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > What exactly does the low boost setti... [ « Previous ] [ Next » ]
