Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > DLS 3way = 2/4ohm load?
Author Thread: DLS 3way = 2/4ohm load?
Username: Tragedy
San Jose, CA
Post Number: 54
DLS 8.3 components use two passive crossovers. One powers the midrange and the other powers the woofer/tweeter. The way they suggest hooking that up is running 1 line to the midrange filter and then splicing into that line and running a seperate one to the other crossover for the woofer/tweet outputs.
Would this present a 2ohm load to an amplifier? or would this still be a 4ohm load? i am trying to pick out an amp and i can go with the lower model at a cheaper price if its a 2ohm load.
http://dls.se/pdf/maniridium_eng.pdf
if you go to page 3 they show you exactly what i am describing you..
Thx
Username: Jonathan_f
GA
Post Number: 3460
It will present a 4 ohm load same as if the crossover were in a single location. The reason that they come with seperate crossover modules is to reduce chances of driver crossovers interfering with one another.
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > DLS 3way = 2/4ohm load? [ « Previous ] [ Next » ]
