Thread: Solo avalanche 15" What amp is the best?! |
Bronze Member Username: Kevints
Ponca City,
OK
United States
Post Number: 12 Registered: Mar-05
| Posted on Thursday, March 10, 2005 - 05:52 pm: |
I am going to buy a avanlanche 15" but i haven't figured out what amp will go very good with the sub. I am looking at 700. 299 for the sub. SO i will have about 450 left over. Any good suggestions and comments. It's going into a 1992 bmw 325i |
Ponca City,
OK
United States
Post Number: 13 Registered: Mar-05
| Posted on Thursday, March 10, 2005 - 06:19 pm: |
Is this a good pick? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5757906247 %26 |
Ponca City,
OK
United States
Post Number: 14 Registered: Mar-05
| Posted on Thursday, March 10, 2005 - 06:20 pm: |
Ponca City,
OK
United States
Post Number: 15 Registered: Mar-05
| Posted on Thursday, March 10, 2005 - 06:22 pm: |
ORION 1200D CLASS D MONO AMPLIFIER 1 X 425 @ 4 Ohm RMS 1 X 850 @ 4 Ohm Peak 1 X 725 @ 2 Ohm RMS 1 X 1450 @ 2 Ohm Peak 1 X 1200 @ 1 Ohm RMS 1 X 2400 @ 1 Ohm Peak Selectable 12/24 dB/octave variable low-pass filter Intelli Q bass optimization circuit and remote gain option Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs Copy/Master feature supports gain and crossover adjustment matching in multiple amp Allows external bridging of two matched gain amplifiers Switchable phase invert function Heavy gauge direct-wire high current satin finish power and speaker terminals
Gold Member Username: James1115
Wilton,
Ct
Post Number: 1893 Registered: Dec-04
| Posted on Thursday, March 10, 2005 - 06:38 pm: |
no dont go with that amp. I would go either with a orion 250 HCCA(perfect run at 1ohm), I have a PPI a600.2 running my avalanche 15 running at 4ohms and it sounds awsome. Joe Smoe is gonna be running his avalanche with a orion 250 HCCA GS. |
Wilton,
Ct
Post Number: 1894 Registered: Dec-04
| Posted on Thursday, March 10, 2005 - 06:39 pm: |
| Posted on Monday, March 14, 2005 - 12:32 am: |
What is the idea wattage for the Avalanche 15? Also, any more on the 12? |
