Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Battery died.
Author Thread: Battery died.
Username: Chinaman_87
Houston, Tx
Usa
Post Number: 21
hey my system is killing my battery but it didnt do it when i first got my system. i know it could be the alternator but could the power be running off somewhere? if so, where? thanks.
Username: Carguy
Post Number: 1859
If your battery is dying, then the alternator is not supplying enough power. Does your lights dim during heavy bass note?
A battery dying is a serious warning sign. Don't ignore it.
Houston, Tx
Usa
Post Number: 23
well my battery was 3 years old so we replaced it? and it didnt seem like it was dimming on high bass. is there anyway to shut off the connection from the ground to the battery?
Username: Carguy
Post Number: 1861
Why would you want to do that? You'll practically shut off every electrical components in the car.
3 years seem to be the average life of a battery. Although mine is lasting longer than 4 years.
Houston, Tx
Usa
Post Number: 25
i just want to shut off the connection from my system to the battery without unscrewing and screwing. is that possible? would that even help?
Username: Carguy
Post Number: 1864
No, ground wires in the car were designed to be screwed on tight. Why do you need to physically disconnect the power wires from your system? That's what the remote wire is for. To turn off the amp when the HU powers off.
Home > Message Board > Car Audio > Amplifiers > Archive through March 15, 2005 > Battery died. [ « Previous ] [ Next » ]
