Thread: I think my speakers exploded |
Bronze Member Username: Tips
Post Number: 85 Registered: Jan-05
| Posted on Wednesday, March 09, 2005 - 10:35 pm: |
my front left speaker stopped working. i installed a alpine 9845 and im using factory speakers. is it a loose wiring problem? sometimes it works. sometimes it doesnt. when it does it kinda crackles. |
Bronze Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 64 Registered: Feb-05
| Posted on Wednesday, March 09, 2005 - 10:39 pm: |
most factory speakers are only rated at like 5 watts peak. you went from 5 watts or less to 18-26 watts. your over powering them by like 3 times, lol |
Bronze Member Username: Kklagge
Post Number: 100 Registered: Dec-04
| Posted on Thursday, March 10, 2005 - 07:00 am: |
Then again it could be a loose wire if that's the only speaker that is affected. |
Post Number: 86 Registered: Jan-05
| Posted on Thursday, March 10, 2005 - 09:17 am: |
yea, i kno im over powering them, but im not actually turning up the volume too loud... i think. damn it, ill just go remove it and check the wires. |
Silver Member Username: Rds11
Louisville,
Kentucky
Post Number: 109 Registered: Nov-04
| Posted on Saturday, March 12, 2005 - 09:51 pm: |
Whenever you get an aftermarket H.U. you should always replace the factory speakers. Especially with getting an Alpine Receiver which are very good, if you haven't already then you will blow your speakers. get new ones |
Post Number: 97 Registered: Jan-05
| Posted on Sunday, March 13, 2005 - 08:48 pm: |
i will be getting new speakers, but its hard for me to decide which ones... heres what ive got so far in my other forum... http://forum.ecoustics.com/bbs/messages/4/126956.html |
