Thread: Kenwood amp and subs |
car audio noob Unregistered guest |
| Posted on Wednesday, March 09, 2005 - 04:38 pm: |
Hi I am a noob when it comes to car audio but I recently purchased a kenwood Kac-7202 920 watt amp, two 10" kfc - w2509 700watt subs and a q-logic sub box. I wanted to know if this is a decent set up and if this amp is powerful enough to power the subs I would also like to know your opinions of the quality of sound. Just to let you know I payed around $300 for everything. |
New member Username: Joe_c
Oakwood,
Ga
Post Number: 10 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 07:55 pm: |
you get what you pay for bro but ok for starts |
Bronze Member Username: Rds11
Louisville,
Kentucky
Post Number: 90 Registered: Nov-04
| Posted on Wednesday, March 09, 2005 - 08:52 pm: |
Kenwood's stuff is around mid grade. for a noob, that is a great way to start seriously. Its not expensive and you get experience. My 1st system was less than that. Take that and gain experience and knowledge and do research so that when that one breaks down or if u are tired of it then you will know what you want in your next one. Since u r a noob I dont know if u are giving me the peak or rms ratings. The RMS rating is far more important than peak, peak is practically useless because u never attain peak power |
| Posted on Thursday, March 10, 2005 - 04:52 am: |
Amp is 920W peak output @ 4 ohms, bridged 460W x 2 peak output @ 2 ohms 300W x 2 peak output @ 4 ohms 460W RMS (continuous), bridged 150W RMS (continuous) x 2 @ 4 ohms 230W RMS (continuous) x 2 @ 2 ohms High-pass/low-pass selectable crossover; bass boost Cast-aluminum heat sink with aluminum dress plate Toroidal noise suppression filter Gold-plated terminals Subs are Product Height 10-7/8" Product Width 10-7/8" Product Weight 8-1/2lbs. Product Length 5-1/4" Woofer Size 10" Woofer Material Pearl-mica-filled polypropylene Magnet Size 145mm x 15mm, 1400 g Magnet Type Double magnets Continuous Power Handling 175 watts Peak Power Handling 700 watts Impedance 4 ohms Connection Type Screw-binding terminals Number of Voice Coils Single Efficiency 91dB Frame Material Stamped metal Surround Material High-roll foam
