Thread: Need more sound |
Bronze Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 56 Registered: Feb-05
| Posted on Tuesday, March 08, 2005 - 06:29 pm: |
hey, i just finished installing my 13W7 and 2 500/1's in a ported box and it sounds great. but now my mids and highs are almost wiped out, lol. i have fiberglass kick panels with boston RC620's being powered by an alpine mrv-t420, about 125 watts x 2. (mb quartz won't fit because of flush mounting system) in the rear i have boston fx 6.5's powered by the head unit (alpine cda 9813) but they might as well not even be there, can't hear them at all. any suggestions on how to get more sound up front? new components? more power?.... thanks |
Gold Member Username: Carguy
Post Number: 1945 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 06:04 pm: |
You might want to try higher powered components with a better amp. Alpine isn't the best when it comes to power and SQ. Have you listen to PPI's Art series 600.2 amp? It'll blow the paint off your Alpine amp. Ok it's a bit exaggerated but you will hear SQ improvement. Unless you have a phase shift, the rear speakers will be over powered by your sub.
Unregistered guest |
| Posted on Tuesday, March 15, 2005 - 06:23 pm: |
so how about hook up directions how does the wires go for component speakers and a amp etc. |
Post Number: 1948 Registered: Nov-04
| Posted on Tuesday, March 15, 2005 - 09:07 pm: |
Laserpitman what are you asking? Do you have component system? |
Stockbridge,
GA
Post Number: 95 Registered: Feb-05
| Posted on Tuesday, March 15, 2005 - 10:01 pm: |
oh i know that alpine sucks, i need to replace it with something better. my coponents say they can handel up to 275 watts, but idk about that. i was looking at the JL XR's, i can bi amp/wire thoes with 2 300/2's, you think they can handel that much? kinda wanna keep everything JL as for the rear, i'm just gonna take thoes out and just run the front components |
