Thread: Selecting an amp |
Unregistered guest |
| Posted on Monday, March 07, 2005 - 09:39 pm: |
I am looking for an amp to run my new Infinity 1030w sub, two 6x9's, and two 4in speakers. The sub has an RMS of 250w. I was looking at an Alpine MRP-F240, because it has a good sound to noise ratio and low distortion. However it only puts out 80w on a bridged channel. Would this be enough for my system or should i get a more powerful amp? I have a tight budget of about $200. Thanks for your help |
Silver Member Username: Tdbdrummer
Post Number: 228 Registered: Feb-05
| Posted on Monday, March 07, 2005 - 11:18 pm: |
Get a HOME AUDIO Carver Power Amp, and wire it in parallel to your gas tank...then divide the amperes by 2 times the alloted trunk space in your car! Oh boy, this is what happens when PEOPLE DON'T ANSWER MY QUESTIONS AND BEAT AROUND THE BUSH!!!!!!!!! |
Gold Member Username: Carguy
Post Number: 1768 Registered: Nov-04
| Posted on Monday, March 07, 2005 - 11:45 pm: |
Coloradorocker87, that Alpine amp is too weak. Not only that, it's over rated. Since you're on a tight budget, Audiobahn's A6004T or A8002T amp will be a good choice for you. I've personally tested that amp and it works well.
