Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Subwoofer ohm rating
Author Thread: Subwoofer ohm rating
I just purchased an alphasonik 5 channel amplifier to complete my system. After buying the amp I realized that the subs I am using (Rockford Punch 10's) are rated at 4 ohms only. I want to run them both on the 5th channel of my amp at 2 ohm to get the most rms. Is this a possible senario. Can I even run the two subs together on the same channel at 4 ohms. The rest of my 4 channels are going to run my 4 Focal polyglass 6 1/2 component door speakers and tweets. I will run the door speakers at 4 ohms because the rms is around 75 watts rms per channel. I just want good clean sound with ample bass. nuthin major. Is alphasonik a good amp for this? Also, I have a clarion deck in right now and it has a 4 volt pre out. Will I be able to tell the difference in sound quality and loudness by adding the amp. Thanks, the BEGINNER!!!
Username: Glasswolf
NorthWest, Michigan
Post Number: 7490
you have an amp with a 5th, class D mono output for subs.
you have two single-coil 4 ohm subs.
wire both subs in parallel to the 5th channel.
problem solved.
should work wonderfully.
beechairplanes
Thanks for the reply. sounds pretty simple. Any thoughts on the alphasonik pmz12005a amplifier?
Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Subwoofer ohm rating [ « Previous ] [ Next » ]
