Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Almost have the decision made...one l...
Author Thread: Almost have the decision made...one last pointer needed!
Username: Tdbdrummer
Post Number: 206
Ok, I'm down to my final three picks. HELP ME OUT HERE! Don't tell me other amps, these are my three choices! In no particular order.
Choice A: Phoenix Gold Octane R8.0:1
Choice B: Audiobahn A8000T
Choice C: Kicker KX-600.1
Someone with knowledge pick the one for my 2 Volfenhag ZX-4712 DVX'x 500RMS 1000Max subs. I myself can't decide!
Username: Jwbulger79
Florida
Post Number: 172
not much knowledge, but kicker's got my vote.
Username: Invain
Michigan
United States
Post Number: 1444
C
Post Number: 208
OK THEN KICKER IT IS!!!!!!!!!!!!!!! Thank you folks I'll see you next week on "PICK MY CAR AUDIO!"
Post Number: 209
I figure that's about 300RMS for each sub, I can go a little higher on the gain, and by the time I add bass boost, AND the headunit crank I should be fine wihtout drawing too much power...IM A FREAKING GENIOUS! Or extremely resourceful. Although should I consider amping my VOlfenhag 5x7's in the future? They are maxed at 350. Prolly like 175 rms. ALthough we ALL know that no door speaker can truly go above 100! Its just not big enough. Maybe a 6x9, but not any 5x7, but what about that amping of them?
Username: Glasswolf
NorthWest, Michigan
Post Number: 7489
kicker, then PG, and about # 23 on teh list, I'd pick audiobahn.. if forced at gunpoint.
I'd also suggest better subs.. that kicker amp is great though.
Username: Carguy
Post Number: 1787
I'd pick Orion 250G4 amp first, then Kicker, followed by A8000T. Glass has his reasons why he hates Audiobahn and I respect that.
For $130, you can't beat it. For an amp that's suppose to be fragile, it survived frost and -25 degree test this winter.
Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Almost have the decision made...one l... [ « Previous ] [ Next » ]
