Thread: Imaging/Rear Fill |
New member Username: Ab0tj
Post Number: 10 Registered: 02-2004
| Posted on Wednesday, February 18, 2004 - 07:23 pm: |
The speakers that I bought for the rear have seperate inputs for the mid and the tweeter (external crossover). So, if I'm not mistaken, it would be good for my imaging if I left the tweeters disconnected, right? Then I just use the component tweeters in the front. Thanks Alex |
Bronze Member Username: Ab0tj
Post Number: 11 Registered: 02-2004
| Posted on Wednesday, February 18, 2004 - 07:37 pm: |
Also, any tips on improving imaging overall?? |
Post Number: 1261 Registered: 12-2003
| Posted on Thursday, February 19, 2004 - 12:45 am: |
you can just use the mids, or if the crossovers have a -3dB connection for thw tweeters try those that will quiet down the highs a bit, and still give good full range for back seat riders
Post Number: 12 Registered: 02-2004
| Posted on Thursday, February 19, 2004 - 12:59 am: |
I'll see (they're still on the way) if they have that. One other thing I thought of, was connecting the mids without a crossover (I will be running high pass on the amp anyway), and that might quiet the highs a bit too. What do you think? Thanks alot Alex |
| Posted on Wednesday, March 24, 2004 - 11:40 pm: |
You may also think about putting a separate amp on the rear speakers. In my experience, it has worked well for my rear speakers to have ~1/4 of the power of the front components. Or, you could amp the fronts and run the rears off the head unit. |
