Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Battery keeps dying because of amp LE...
Author Thread: Battery keeps dying because of amp LED maybe
Username: Bulldogsm2008
I hooked up my amp myself and used scoshce wiring and when i shut of my car the LED on my amp doesnt shut off and kills my battery overnight. I think i have everything hooked up right. If you think you may know whats causing my battery to die help. I have a dual amp only 340 watts max
Username: Kojak28
Augusta, GA
Post Number: 63
If the led light is on, that means the REM wire is sending a signal to the amp to turn on. Make sure you have the right REM wire patched into on the back of the HU.
Thank you alot
Username: Kojak28
Augusta, GA
Post Number: 65
No sweat, Dude.
Username: Marines
Post Number: 12
make sure u have the remote wire 2 remote on the back of the hu and not the constant usually an orange color wire dont hook it 2 that
Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Battery keeps dying because of amp LE... [ « Previous ] [ Next » ]
