Thread: CORRECT IF WRONG PLEASE! |
Silver Member Username: Tdbdrummer
Post Number: 154 Registered: Feb-05
| Posted on Sunday, March 06, 2005 - 07:00 pm: |
Well how about my Audiobahn A8000T? It's only 400RMS @ 4ohms, and 800RMS @ 2ohms. I did a little math according to CC's site. Correct me if I'm wrong. They said to push a 4000W amp it takes 286 amperes of power. Well my 800W is 1/5 of that, so my amp would require 1/5 the power correct? Approx. 57.2 Amperes. I also used a formula I found on several websites converting watts to amps. It was W/V=A. According to my formula, if I use 800W RMS and 14.4V, I get 55.55555 Amperes. If I use 800W RMS and 12V it is 66.66666 Amperes. My stock alternator is I believe 80A, if so why shouldn't I be able to use that amp? I REALLY REALLY REALLY don't want someone messing with that stuff in my car. There has to be another solution. |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 850 Registered: Jan-05
| Posted on Sunday, March 06, 2005 - 07:06 pm: |
Don't forget about headlight's, the AC, and all the other electrical thing's. |
Post Number: 156 Registered: Feb-05
| Posted on Sunday, March 06, 2005 - 07:10 pm: |
If that amp will not be able to be run, how about the JBL GTO 601.1. It will provide my subs with almost 300W RMS each. They are 500W RMS each, I don't think that would be underpowering them too terribly would it? |
Post Number: 164 Registered: Feb-05
| Posted on Sunday, March 06, 2005 - 07:54 pm: |
Anyone? |
