Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Speaker Box
Author Thread: Speaker Box
Username: Vaio
Post Number: 44
I got a Sub that is for a 1.5Cu.ft Box But i made at 1.9Cu.ft will it sound better if the box is a bigger box are do the subs sound better with a smaller box.
Username: Tdbdrummer
Post Number: 148
Is it a Sony XPLOD sub????????? If so, it won't sound good period.
Username: Vaio
Post Number: 45
NO is not a sony is for a friend is a Audiobahn AW1206T 12" Flame.
Will it sound in bigger Cu.ft Enclosed are smaller Enclosed like 1.5Cu.ft are smaller?
Post Number: 158
Sealed or Ported? Sealed generally need to be deeper. Ported can be either deep or shallow. Have to consider mounting depth of the sub itself as well.
Username: Taylor17
Kopperl, Texas
Post Number: 853
Bigger usually gives it a more boomy sound.
Username: Vaio
Post Number: 46
sealed what Cu ft will guys think will be for the Best sound out of the SuB?
Username: Invain
Michigan
United States
Post Number: 1385
Generally the smaller the sealed box the higher the spl. Make the sealed box larger and you'll get a little more out of the low end.
Post Number: 161
Mine is 13"High, 13"Deep, and 28"Wide, and it sounds just fine. Got it from Ebay for 20 bucks plus 2 150 each tweeters. Box is very well made. I wish I knew how to run the tweeters though. Anyone know how?
Home > Message Board > Car Audio > Amplifiers > Archive through March 08, 2005 > Speaker Box [ « Previous ] [ Next » ]
