Thread: Engine noise.. help !! |
Bronze Member Username: Bassfreak596
Post Number: 88 Registered: Oct-04
| Posted on Sunday, March 06, 2005 - 01:57 pm: |
i recently installed a hifonics bx1500d for my eclipseTi. after i switch the sub off from my HU and HonK.. i get disturbance in my front dash speakers.. they are tiny speakers maybe 3 inches and i think are directly connected to the HU. i also sometimes get a shock on my car body.. i hope now that it is static ! is there anything wrong with my ground ? |
Post Number: 89 Registered: Oct-04
| Posted on Sunday, March 06, 2005 - 02:30 pm: |
anyone ? |
Bronze Member Username: Kojak28
Augusta,
GA
Post Number: 56 Registered: Feb-05
| Posted on Sunday, March 06, 2005 - 02:37 pm: |
DEFINITELY A GROUND ISSUE. Nice sub and amp setup tho'. Are you running the RCA cables down a different side than power wires? |
Post Number: 90 Registered: Oct-04
| Posted on Tuesday, March 08, 2005 - 12:21 am: |
the amp is under my right front seat.. so the rca cables and the power wire ARE running together for some distance.. hey i m using the 8ga power/ground wire.. could that be an issue ? |
Gold Member Username: Invain
Michigan
United States
Post Number: 1474 Registered: Aug-04
| Posted on Tuesday, March 08, 2005 - 12:22 am: |
The rca and the power next to eachother is probably your issue. |
Post Number: 91 Registered: Oct-04
| Posted on Tuesday, March 08, 2005 - 12:23 am: |
and everything was perfect before the new hifonics.. i mean with the mids and front speakers.. |
Post Number: 92 Registered: Oct-04
| Posted on Tuesday, March 08, 2005 - 12:26 am: |
so i need to run them from the opposite sides, yey ? |
Silver Member Username: Sublime420
Ca
Us
Post Number: 131 Registered: Jan-05
| Posted on Tuesday, March 08, 2005 - 12:39 am: |
yes, you should. |
