Thread: Whats the RMS of HCCA250 at 14.4V???(1ohm) |
subamps Unregistered guest |
| Posted on Thursday, March 03, 2005 - 11:40 am: |
i am going to buy a hcca250 amp, but i wanna know what it will really put out at 1ohm. anyone here know what it will really do at 1ohm? also, should i get the hcca250 or a jbl bp1200.1? what other amps would u suggest? |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 1484 Registered: Dec-04
| Posted on Thursday, March 03, 2005 - 11:53 am: |
there is no compatition between those two amps. Go HCCA all the way. Its output at 14.4 volts is around 950 watts. But remember it is true power where the JBL is rated at 1200 at 14.4 and it will prob only do 1100 so they are very close in power but the class a/b over the class D makes the Orion a far superior amp also the slew rate,damping factor,gold line inputs,and lots of other things that I am sure Isaac will tell you about I think he has the post saved because he has to write it like 3 times a day lol. |
