Thread: Amp for 6 speakers? |
Bronze Member Username: Point78
El cajon,
Ca
Post Number: 12 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 09:49 pm: |
Hey everyone i have 4 4x6 inch speakers at 60watt rms and 4 ohms, and also a set of 6.5 inch compenents at 90watts rms and 4 ohms what kinda sub should o get 4 channel or what and how would i wire 6 speakers to a 4 channel amp or do they make 6 channel amps? any input would be welcome |
Bronze Member Username: Blindmp2
Post Number: 18 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 10:13 pm: |
why do u wanna devide taht much watts to 4 speakers and a sub, , just get another amp for a seperate woofer, trust me that would be better, thats how i have mind set up |
El cajon,
Ca
Post Number: 14 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 10:35 pm: |
sorry i ment to say what kind of AMP shuould i get 4 channel or what and how would i wire six speakers, i already have my two subs hooked up to a seperate amp my bad |
Bronze Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 30 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 10:50 pm: |
you can wire 2 pair in parallel off of one channel, but you'll have to add an 8ohm resistor to keep it at 4 ohms. i'd think it would sound funny though. theres an example on the jl web site unter tutorials. jl makes a 6 channel amp, but its only 45 watts X 6 at 4 ohms. thats the only 6 channel i know of. are you trying to make is a true 6 way system or are you just looking for loudness? |
El cajon,
Ca
Post Number: 16 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 11:34 pm: |
well i dont really know this is how the truck came when i got it, i added my subs and there is already and amp to the 6 speakers but it is only 2x 30watts and i am upgrading and would like a little more bang to keep up with my subs if you know what i mean, i was thinking may be i should wire the four 4x6's together and have the component set by itself may that will work.
Gold Member Username: Carguy
Post Number: 1668 Registered: Nov-04
| Posted on Wednesday, March 02, 2005 - 11:53 pm: |
You can buy 4 channel amp that's 75w - 125w rms. Most of them are 2ohms stable in stereo mode, so you will be able to pair up the 4x6 speakers with channels 1 and 2. Then power your other 2 speakers with channels 3 and 4. If you're into sound quality, then look at Zapco/Arc Audio/Xtant/US Amps/Orion/JL/PPI brands. If you're trying to save money, then try Audiobahn/MTX. |
El cajon,
Ca
Post Number: 19 Registered: Feb-05
| Posted on Thursday, March 03, 2005 - 09:21 pm: |
i could wire the 4x6's together to equal 2 ohms but the 6.5 by them self would be 4 ohm can i have 4 ohms on two channels and 2 ohms on another channel |
Post Number: 1689 Registered: Nov-04
| Posted on Thursday, March 03, 2005 - 09:22 pm: |
Yes it'll be fine with 4 channel amp. |
El cajon,
Ca
Post Number: 20 Registered: Feb-05
| Posted on Thursday, March 03, 2005 - 09:37 pm: |
kewl thanks for your help
