Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Speakers static
Author Thread: Speakers static
Username: Blindmp2
Post Number: 17
my speakers work great before but then i put on the radio and theres a good song on and of course ima bump it but them it gets all staticy when i bump it why is that? or what is ahappening wrong
if you don't have an amp, then when you turn your headunit way up, it cannot give the power it needs to have clear sound, so it starts sending a clipped signal to the speakers creating distorted sound.
Another scenario is if you got an amp, it might be too powerfull for your speakers and you might just be pushing the speakers too much.
Username: Blindmp2
Post Number: 23
i have a amp but for the woofers thats all
JL
you must have amps for your speakers dude. stock speakers can't handle it.
Username: Blindmp2
Post Number: 32
they aint stock speakers
Username: Araknid
BOCA , FL
U.S.
Post Number: 323
its not the HU its the speakers cause they cant handle the bass. if you put the bass all the way down then i bet you can put the volume on full blast.
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Speakers static [ « Previous ] [ Next » ]
